Unable to save new polygons in 2.3
1894
12
01-25-2019 02:06 PM
LiamTurley
Updated to 2.3 unable to save new polygons while digitizing. No error code just message informing me it does not work.
Scott_Harris
Hi Scott,
I'll mention the same thing I said to Liam: Please open a case with Esri Technical Support. The phone number is 888-377-4575. Please let me know once you have an open case, or if you hit any roadblocks.
Liam didn't see the issue in another File Geodatabase. Do you see the same problem in different or newly created File Geodatabase?
Thank you,
-Scott
ScottSweet2
Hi Scott,
I did not have the same problem when I created a new/empty file geodatabase
so I think it is the same as Liam. I was also able to edit another feature
class (points anyway) from one of my preexisting databases.
Scott
Scott_Harris
Hi Scott,
Ok so that's good. We'd still like to get to the bottom of it. It's probably best if we work through a Support case, but here are the type of questions I would ask:
  • Can you import (you can use copy/paste) the problem feature class into the working File Geodatabase? Does it still exhibit the editing issue?
  • Was the problem geodatabase a Project File Geodatabase (FGDB) that was part of the last ArcGIS Pro Project you worked on before upgrading to 2.3?
  • Do any other Project FGDB's have the same problem?
Thanks for any further insight.
-Scott
