Unable to render stereo model in ArcGIS Pro
937
05-01-2025 09:46 AM
Labels (2)
wizgis
We are trying to set-up a stereo map in ArcGIS Pro however, when we add left & right image in Set Stereo Source dialog box it gives an error of "The given images do not make a valid stereo model". We suspect this is happening because the Pro is not able to read the associated .RPC file which is in .RPB format following this documentation : https://pro.arcgis.com/en/pro-app/latest/help/analysis/image-analyst/stereo-map.htm
Attached is the screenshot for the reference.
Note : The images have been downloaded from maxr
Hence, just wanted to know if there is any step that we are missing.
wizgis
Was able to resolve the issue after renaming the .tiff file same as .RPB file
wizgis
