Unable to add ArcGIS Server to ArcGIS Pro
1058
10-06-2024 07:04 PM
AprilWheeler
Two years ago I did a remote sensing project by adding this server https://landsat2.arcgis.com/arcgis/rest/services/Landsat/MS/ImageServer to ArcGIS Pro. I added this server in ArcGIS Pro under Insert, Connections, New ArcGIS Server. I am now trying to use this server to complete another project and it's not working. I follow the steps to add it, click Ok, and a box pops up and says that it's connecting, then the box closes and nothing happens. I remember two years ago it took several hours to download, but now literally nothing happens. It's as if I never added it. I made sure my software was up to date, but that didn't change anything. Any suggestions to get this to work, or any other similar servers/other ways you would suggest to complete a remote sensing project? I know there's https://livingatlas.arcgis.com/landsatexplorer now but I really preferred the way I was able to edit the images in ArcGIS Pro by editing the sampling type, stretch type, etc.
JakeSkinner
Esri Esteemed Contributor
@AprilWheeler ,
Make sure you are using the following URL when adding the ArcGIS Server connection:
sjones_esriau
Hi April,
Check your catalog pane after connecting, the server should be there.
JakeSkinner
@AprilWheeler ,
