Should Append tool perform Update and Add at the same time
4807
13
09-18-2024 12:20 AM
Labels (3)
LindsayRaabe_FPCWA
MVP Regular Contributor
Hi All. I'm using the Append tool in ArcGIS Pro, and in arcpy to try and both ADD new features to a feature service in ArcGIS Online (from a feature class), as well as UPDATE existing features if they match (Upsert).
From reading the documentation here I understand that the tool should look for features with identical attributes within the fields listed under the "Update Options" section. If a feature in the Input Dataset matches a feature in the Target Dataset based on those fields, then it will update all the fields listed in the Field Map (as well as the Geometry if that option is enabled at the bottom of the pane). If no matching feature is found, then those features in the Input Dataset should be Appended as new features.
However, the behavior I'm getting doesn't seem to match that. When I have no Update fields listed, the features in my Input Dataset are being appended as New features as expected. When I do have fields listed under the Update Options section, I am seeing matching features update but new features are not being added as I would expect.
Can someone clarify if there is a problem somewhere, or if I have my understanding wrong and the Append tool is either Add or Update, not both?
Lindsay Raabe
GIS Officer
Forest Products Commission WA
DanPatterson
MVP Esteemed Contributor
Nothing gets fixed unless it gets reported.
Also, there is a link on the help topic page that you can supply comments for the help topic.
I find regularly that any lack of clarity in a help topic is address by correcting an error, or by that team contacting the appropriate section within esri to confirm what is written.
Could just be me, but it would be worth reporting, especially since beta 3.4 will be coming up
... sort of retired...
ChristopherCounsell
MVP Frequent Contributor
The exact issue that Lindsay is describing was reported as a defect in 3.1 and fixed in 3.2.
Lindsay is on 3.1.
There's no benefit to reporting it as they will ask you to update and test the issue on the version where the issue has been fixed. May as well do that first.
I'm also not seeing any issues with the documentation, it seems like the user hit a known defect.
SFM_WillBrewer
This issue does not appear to have been fixed. I am experiencing it in 3.2..
AaronKoelker
