Shortcut to run Geoprocessing removed?
1683
09-09-2020 02:50 PM
DanielCardenas
In Pro 2.5 I was able to use the keys Ctrl+Shift+Enter to run a GeoProcessing tool, but I can't anymore after updating to 2.6. Was this removed - or do I have a bug in my install?
(This was a not-well documented feature mentioned in this thread: https://community.esri.com/message/869472-re-shortcut-to-run-a-geoprocessing-tool?commentID=869472#c... )
DrewFlater
Daniel Cardenas We are tracking this regression in 2.6 -- the shortcut will be added back to 2.7 at least, and we may be able to include in a 2.6.x patch depending what we find is the problem.
DanPatterson
MVP Esteemed Contributor
Drew Flater
In the interim, perhaps you might be interested in the current complete list of shortcuts
ArcGIS Pro keyboard shortcuts—ArcGIS Pro | Documentation
... sort of retired...
DrewFlater
DanielCardenas
Thanks very much Dan Patterson‌ & Drew Flater‌. I look forward to the reintegration of the shortcut.
DrewFlater
Daniel Cardenas
The shortcut has been re-added to the Pro 2.7 alpha/early adopter snapshot. Thank you for reporting the problem.
DanielCardenas
Awesome! Thank you for doing this.
