I'm trying to select swInlet points that fall within 100 meters of a set of line segments. When I run the tool, it selects 0 features and then tells me "The input has a selectin. Records to be processed: 0." I've done the following troubleshooting:
(Using ArcGIS Pro 3.1.1)
Check to make sure the layer is selectable
There is no definition query on the layer I want to select
The Select tool "Selection combination mode" is set to "Create a new Selection"
I created a 100 meter buffer and tried to select the layer with that
I've cleared the selection before running the tool
I've tried using Intersects, Completely within, within a distance of
I've tried Inverting the Spatial Relationship: This selects every feature
What am I missing?
Another option to solve this, although @DanPatterson is almost always right, is to check if all your data is projected in the same system. Old problem for sure but might still work for you
did you open the swinlet table and double-check that there is no record selected?
If so, try a reboot of Pro.
If that doesn't work, export the swinlet featureclass to a new one, check it, and use it for the select by location
Tech support might be a go as well.
That was it! They were in different projections. Thank you!
