Title edited. Originally "1:M Join — Select By Attributes handling nulls incorrectly."
ArcGIS Pro 3.2.2; File Geodatabase:
I've joined TABLE_A to TABLE_B via common ASSET_ID text fields using Add Join. The join is one-to-many: 1 row in TABLE_A to 4 rows in TABLE_B.
I want to select from TABLE_B.ROAD_NAME (text) where ROAD_NAME is null. However, Select By Attributes doesn't seem to work correctly. It selects all four rows, regardless if ROAD_NAME is null or not.
Video:
Notes:
- I have the same issue in ArcGIS Pro 2.6.8 in a file geodatabase and in an Oracle 18c 10.7.1 enterprise geodatabase.
- I don't have this problem with definition queries in ArcGIS Pro 3.2.2, only with Select By Attributes. There is a separate issue in 2.6.8 with definition queries: Esri Case #03387420 - Definition query on join returns incorrect rows.
I don't understand how that issue has been around since ArcGIS Pro 2.6.8 (or earlier) and is also in 3.2.2. How could such a serious issue not have been fixed as of 3.2.2?
