ReportLab Package in ArcGIS Pro 3.3.0
2329
05-30-2024 03:09 PM
MikeVolz
To All ArcGIS Pro Users:
I am trying to run a python script that requires ReportLab.  I realize that ReportLab is not a python package included by default, so I created a clone.  Now when I create the clone, I cannot find ReportLab as an additional python package with Pro 3.3.0 even though I can find ReportLab with previous versions of Pro (e.g. Pro 3.2.x).
Has anyone else encountered this issue?
If so, is the only current solution to downgrade ArcGIS Pro back to Pro 3.2.x?
Any help or hints are greatly appreciated.  Thanks in Advance
Mike Volz
DanPatterson
MVP Esteemed Contributor
it is there on the Esri anaconda channel
... sort of retired...
MichaelVolz
How do I get Pro Package Manager to recognize this channel?
DanPatterson
did you try conda rather than the package manager?
as shown in the link's other pages
conda install reportlab
or
conda install esri::reportlab
if you want the actual version
(arcgispro-py3) C:\arc_pro\bin\Python\envs\arcgispro-py3>activate spyarc
Current directory is another environment, changing directory to active environment.
(spyarc) C:\arc_pro\bin\Python\envs\spyarc>conda install reportlab --dry-run
Collecting package metadata (current_repodata.json): done
Solving environment: done
## Package Plan ##
environment location: C:\arc_pro\bin\Python\envs\spyarc
added / updated specs:
- reportlab
The following packages will be downloaded:
package | build
ca-certificates-2024.3.11 | haa95532_0 128 KB
openssl-3.0.13 | h2bbff1b_2 7.5 MB
reportlab-3.6.13 | py311h2bbff1b_0 3.2 MB
Total: 10.8 MB
The following NEW packages will be INSTALLED:
reportlab pkgs/main/win-64::reportlab-3.6.13-py311h2bbff1b_0
The following packages will be UPDATED:
ca-certificates 2023.12.12-haa95532_0 --> 2024.3.11-haa95532_0
openssl 3.0.13-h2bbff1b_0 --> 3.0.13-h2bbff1b_2
DryRunExit: Dry run. Exiting.
(spyarc) C:\arc_pro\bin\Python\envs\spyarc>conda install esri::reportlab --dry-run
## Package Plan ##
- esri::reportlab
package | build
freetype-2.13.2 | 0 1.2 MB esri
reportlab-3.6.13 | py311_0 3.0 MB esri
Total: 11.7 MB
reportlab esri/win-64::reportlab-3.6.13-py311_0
freetype 2.10.4-vc14_3 --> 2.13.2-0
DanPatterson
followup BUG-000168096 for ArcGIS Pro (esri.com)
