Python TypeError
4645
06-20-2021 03:37 AM
HamzaM
I am trying to use the Detecting Super Blooms Using Satellite Image Classification Sample Notebook but when i test this code:
map1 = gis.map(address, zoomlevel = 12)
map1.center = location
map1
map1_selected = call_filter_images(map1, "2019-03-18")
img_src=map1_selected
this error occurs
Applicable lockRasterIds= []
TypeError                                 Traceback (most recent call last)
In  [28]:
Line 1:     map1_selected = call_filter_images(map1, "2019-03-18")
In  [26]:
Line 5:     [tdf, selected] = filter_images(my_map, start_datetime, end_datetime, extent = area['extent'])
TypeError: cannot unpack non-iterable NoneType object
HamzaM
The problem was with the date once i changed it, it worked fine.
DanPatterson
MVP Esteemed Contributor
The error message
means None was returned by my_map (which doesn't appear anywhere) and the "filter_images" function was supposed to return and unpack two objects (tdf, selected)
So my_map doesn't exist,
map1_selected isn't used
map1 isn't defined, but maybe not selected.
In short, you will need to backtrack and figure out what wasn't found that returned None
... sort of retired...
HamzaM
