Problem with Created Contour Lines from DEM: Cut Before the End of DEM.
1160
10-06-2023 01:42 AM
VassilisTrigkas1974
I have an issue with contour lines I generate from a digital elevation model (DEM). Even though I created them correctly, at the end of the image, half a meter before the desired area, the contour line gets cut off.
DanPatterson
MVP Esteemed Contributor
Contour (Spatial Analyst)—ArcGIS Pro | Documentation
did you specify an extent and snap raster?
see the paragraphs just above the Parameters section of the link for comments on what might be happening
... sort of retired...
