NWI Wetlands Feature Layer shows all features on legend when "Only show features visible" is checked.
1166
01-21-2022 09:54 AM
Labels (2)
AmberRothwell
I am running into an issue where I am creating a layout with a legend. The legend and the legend item have "Only show features visible" checked. However, I am using a feature layer service from NWI. This wetlands layer in my map ignores the "Only show features visible" setting. I work with this layer daily and it gives me so many problems.
Does anyone else have this issue?
Robert_LeClair
Esri Esteemed Contributor
This is odd behavior.  I'm working with NWI (California) data from ArcGIS Online; added it to a new map view; create a layout; add a legend; set properties with (and without) the check box for "only show features visible in the map extent" - see attached.  It works as expected.
Can you share specifically what web layer you're working with so I may test?
AmberRothwell
