Not able to merge the layers of point data. Only one layer shows up after merging.
11905
27
06-23-2021 04:41 PM
bee
I'm new to this. I am trying to merge two layers of points to one. I went to Analysis > Tools > General > Merge. I entered the two datasets and hit "run." It generated a "merged" later in the content. However, upon checking, I can only see one dataset. I checked by selecting Appearance > Symbology > Unique Value and see that only the values for one set were included in the layer. I'm clueless as to what's wrong because I've done merge in the other project and didn't have the same issue.
Tags (1)
2 Solutions
bee
Turns out I have to shorten the layer names. It works now. Thanks for looking into this for me, everyone! 😊
DanPatterson
MVP Esteemed Contributor
you are asking for problems with those paths.  They contain spaces, and punctuation (excluding _ , which is ok).
as suggested earlier...
... sort of retired...
DanPatterson
don't judge the merge on the symbology.  open the table and see if the number of records in the output table is equal the sum of the two input featureclasses.
If it does, try resymbolizing, since I suspect that the field you used for symbology wasn't present in both tables and you didn't look at the field mapping options
bee
Yea, I checked the Attribute Table and it shows the exact number of one of the two layers. I then switched the order of the layers and merged again; and again, I get the exact number of the other layer.
bee
The field for the symbology does appear in both sets.
DanPatterson
Are they both featureclasses in a gdb?
Why don't you take a screen grab of the dialog from arctoolbox showing the inputs and the output featureclass names.
Waffle_House
Another thing to be careful of is having features selected. Often tools will only operate on the selected features.
bee
No... I didn't select any features..
by Anonymous User
Not applicable
,Hi @bee ,
If you want to keep the attributes data from both layers, you will need to complete a table join Add Join (Data Management)—ArcGIS Pro | Documentation
DanPatterson
Merge (Data Management)—ArcGIS Pro | Documentation
to combine 2 files into one output file... with field mapping
by Anonymous User
Not applicable
That is true or you can use the Append tool to merge the two files into one Geodatabase Append (Data Management)—ArcGIS Pro | Documentation
