Thank you in advance for any and all help!
I am currently trying to create a mosaic historical photos for my organization of scanned imagery. I am able to upload my camera and frames tables as CSV's without any issue. After defining my fiducial marks and refining the interior my image looks a lot cleaner. However, whenever I try and use the "Adjust" tool for a block adjustment and line up my images, ArcGIS Pro crashes on me without fail. I am not entirely sure what the issue could be as everything has the proper projection and all my file paths and information seem to be correct but I am still unsure why it won't do a block adjustment for my images.
Currently running ArcGIS Pro 3.3.0
Imported a local DEM from http://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer
Left processing template as Default
Steps taken
-created a new workspace, adding in Camera and Frames table.
-was able to refine interior orientation with my fiducial marks without any issue
-after updating interior orientation, the mosaicked image shows up, with clear overlaps between the images
After clicking "Adjust" I leave the "Focal Length", "Principal Point", "K1,K2,K3", "P1,P2" boxes empty, along with everything else in advanced statistics except the "Compute Posterior Standard Deviation for Images" which was automatically Ok'd for me.
I have tried different variations of the Adjust tool, but nothing seems to work. I've uploaded the csv's that I'm using (I took out the file paths and some other information for privacy purposes, but otherwise everything is intact).
Any help would be greatly appreciated!
