Modelbuilder - Fill in list of values from excel
585
03-30-2023 09:29 PM
Labels (2)
slgissolutions
Hi all,
I'm trying to find a way that I can import a list of values that I have in an excel file into a "List of Values" string variable in my model? I'm trying to avoid having to type each one in manually.
DavidSolari
MVP Regular Contributor
Use "Excel to Table" to load the data into a table, then "Calculate Value" with some Python cursors to join the column values into one big string. Something like this for the code block:
def get_list(table):
    return ";".join(str(x[0]) for x in arcpy.da.SearchCursor(table, "My_Field_Name"))
and then you can call the function like get_list("%output_table%"), replacing the variable with whatever the name of your output table is in modelbuilder.
