Missing parameters for map series exportToPDF method
7418
11
04-21-2021 08:19 AM
JeffThomasILM
I'm trying to export selected pages from a map series (by manually selecting/highlighting them in the Contents pane, or using a SQL query on the index layer) to PDF using Python. The MapSeries Documentation mentions parameters {page_range_type}, {page_range_string}, and {multiple_files} that sound like exactly what I need, but the code examples on that same page don't utilize those parameters. They instead use loops, which would be unnecessary if the above parameters actually worked(?). When using the interactive Python window in Pro, the code completion also does not utilize them. Attempting to use them just throws an error. Am I missing the proper context for these parameters? Are they not implemented (yet)? Please advise. Thanks!
Edit: sorry, I was using the wrong terminology. It is parameters for the exportToPDF method that are missing. I changed all use of the word method to parameter.
JeffThomasILM
Ah! MS vs. Layout also explains why the code complete wasn't working. You were of course right about removing the single quotes from the field name. I thought they were required if using a file GDB, but apparently not. A lot of trial and error went into formatting the SQL statement properly for Python, and that was what I finally arrived at that didn't create an error. However, it also didn't create a selection! Thanks again!
JeffBarrette
Yeah, you had me scratching my head on the missing parameters. 🙂  Again, its a great idea to build the query in the Definition Query dialog and look at the SQL string.  Good luck moving forward.
Jeff
