I'm trying to export selected pages from a map series (by manually selecting/highlighting them in the Contents pane, or using a SQL query on the index layer) to PDF using Python. The MapSeries Documentation mentions parameters {page_range_type}, {page_range_string}, and {multiple_files} that sound like exactly what I need, but the code examples on that same page don't utilize those parameters. They instead use loops, which would be unnecessary if the above parameters actually worked(?). When using the interactive Python window in Pro, the code completion also does not utilize them. Attempting to use them just throws an error. Am I missing the proper context for these parameters? Are they not implemented (yet)? Please advise. Thanks!
Edit: sorry, I was using the wrong terminology. It is parameters for the exportToPDF method that are missing. I changed all use of the word method to parameter.
