Location-Allocation Based on Tiers (cutoff_miles)
322
04-15-2024 07:48 AM
IgorLima
Hello Everyone,
I have the following scenario:
The company I work for has several warehouses. We offer a 4HR delivery service, however, we know that each region has a different infrastructure and therefore, it is not possible to cover the same distance within 4HR. I have managed to determine the possible distance to be covered for each warehouse. Some cover 80, others 100, and others 120 miles.
However, I need to make this logic work using the Location Allocation strategy (Problem type: Maximize Coverage and Minimize Facilities).
The idea is to check, based on the possible distance, how many warehouses I should use to serve a particular network of customers.
I managed to do this through the Closest Facility strategy, inputting the mileage limit in the "Cutoff_Miles" column within the attribute table, but this column does not exist for "Facilities" within the Location Allocation strategy.
Could you help with this point?
Dale_Honeycutt
Just curious, but for the Make Location-Allocation Analysis Layer, doesn't specifying a Travel Mode that uses  time (minutes) instead of distance work for you?  You'd specify a cutoff of 240 minutes for the Cutoff and each facility would cover the 4 hour distance, whether it be 80/100/120 miles.
IgorLima
We generally use distance as a cutoff, because the distance from one point to another will remain the same, however, if we consider time, it will vary according to the traffic, natural disasters, etc.
