join/relate streetlight to pole
941
11-26-2021 10:53 AM
SarahHartholt
Wondering if anyone has developed a workflow to join a streetlight layer to a pole layer.
Workflows I am considering:
use the Near GP tool or Spatial Join to grab the pole number from the closest pole and add it to the Streetlight feature class
Issue: pole clusters
Issue: new subdivisions where streetlight information has been collected but the pole doesn't exist in the pole feature class
LeePenney
The Near Tool is a good choice because it will only select one closest feature. If two poles are the same distance apart it will randomly pick one.
The streetlights with missing poles will have a value of -1 (as long as your search radius is small enough to accomplish that) and you can use that to filter them out.
Adnan_ZahoorAbbasi1
I want to create a tool to Join point and line feature without new output (output feature class) , for example Tower and electric Line.
electric line is spitted on every tower. relation is many to may .
Related feature can be with in 0.8meter.
Anyone cane help regarding this?.
Thanks & Regards,
