Is there a keyboard shortcut option to apply to all geoprocessing execute buttons?
148
07-10-2025 09:40 AM
ThomasHoman
Is there a way to apply a single shortcut command to the execute button for all geoprocessing commands? Something like setting up ctrl+alt+enter (or some other variation) to execute whatever tool is active at the moment.
We are knee deep in cleaning up a parcel fabric conversion and a strictly mouse-centric workflow is proving to be a very low productivity solution for editing. We have a lot of data that has to be cleaned via repetitive applications of tools along the lines of the merge parcel point command. In the below small section we have to to repeat the Merge Parcel Points command 8 times where the platted lot lines were split in AutoCAD and need to be repaired.
Editing efficiencies could be gained by not having to drag the mouse out of the work area and execute the tool when a keyboard shortcut could kick things off. I my setup I have the geoprocessing tools pane undocked and on a separate monitor to expand the work area and have to drag the mouse a relative long ways to trigger the tool.
Thanks for any insight you might be able to share.
Tom
