Is ArcPro just generally slower than ArcMap?
7838
18
02-27-2025 06:30 AM
RandyMcGregor_BMcD
We are finding that ArcPro is - across the board - way slower than ArcMap. Easily 10 times slower on average, and many continue to use ArcMap for this reason, despite its pending deprecation. Calculations, selections, symbology changes, rudimentary geoprocessing, and even selecting records all come with lags that slow down the entire workflow substantially.
I see this icon multiple times a day, often for dozens of seconds, or into minutes, even for simple tasks:
Is this a general fact of ArcPro, or does this indicate a need to makes changes to our infrastructure?
Is it a reasonable expectation that ArcPro is - on average - comparable to ArcMap in general speed?
I realize this is kind of wide open.  Not expecting anyone to fix this. Just trying to get a feel for what our expectations should be and how to respond to this situation.
Thank you,
Randy McGregor
AlfredBaldenweck
MVP Regular Contributor
Yeah, renaming things really shouldn't take as long as it does.
RandyMcGregor_BMcD
Added 4 fields. The fields existed already (my mistake), but the time it took to finish this task is off the charts. Over four minutes. Locally stored data. 1600 records.
This one's interesting. It says 1.46 seconds to complete, but I wasn't given control back for about 2 minutes. The blue wheel just spun and spun after it provided the message saying the procedure took 1.46 seconds.
Luke_Pinner
I've always felt Pro was much faster than ArcMap. I used to dread opening ArcMap, every UI interaction was so slow it was almost unusable. Yes Pro can be slow with data on network drives or over VPN when working remote, but ArcMap was worse for me even working locally.
SteveCole
Honored Contributor
I tend to feel it most when editing because the contextual ribbon UI has to keep changing when you alternate between adding a feature & then modifying it. So many pregnant pauses..
RTPL_AU
Honored Contributor
Hi @RandyMcGregor_BMcD   - have a look if this is a component of your issues:
https://community.esri.com/t5/arcgis-pro-ideas/reduce-the-amount-of-license-checking-in-order-to/idi...
Some things you mention do not sound normal.
Otherwise, in general - Yes. Pro is much worse than ArcMap in many cases.
<Friday rant>
Over the last decade (!!!!!! yes, it is 10 YEARS OLD THIS YEAR)  many things have improved but there are still some components that are just badly designed.
Some of the screen drawing effects (fading things in & out) slow stuff down, regardless of the data involved, but some processes require more clicks than before, or clicks at opposite ends of the screen.
Something that bugs me endlessly is how laggy the Contents Pane is - I find that I have to repeat clicks, or cancel and click again because it constantly lags behind my mouse so the first click is applied to the wrong layer.
This is worse in Pro than anything else I use. Solid Edge comes close but still order of magnitude better. QGIS and ArcMap does not have this at all.
We're not even getting into the dynamic ribbon mess - If only we can get a legacy mode (ArcMap mode) to just pin the toolbars we use often - not a custom one, just the same a fixed location that does not go away every time you click to another layout object and back. There are workarounds but they are fiddly.
I'm not too affected by data stuff at the processing side but housekeeping tasks such as renaming a FC, unhiding a field, etc is just not done well.
One of the best for last - the attribute table view is something someone should be let go over, and told to get a job not involving computers 🤣:clown_face:
It is a constant re-draw, re-order, re-something, laggy mess all the time. Try copy/pasting a few field entries quickly. It will miss at least 30% when I try to work quickly. ArcMap never had that problem for me.
For me, ArcMap reacts better to user input on a 8yr old PC compared to a very serious current top of line workstation with Pro. I should've called my computer Chuck Norris....
At least the AGOL integration is good. If you disregard that many options YOU USE EVERY TIME are hidden behind one or two clicks.
My Pro experience can be summerised as "there is always something". Something that lags, breaks, doesn't save, behaves unexpectedly, creates lines in an urgent PDF, etc.
Being insane is doing the same thing over & over and expecting the outcome to be different. With Pro, doing the same thing many times WILL see at least 1 or 2 instances of it just picking a random way to waste your time. At least I will never go insane while using it so here's to lifetime memberships.......
Overall though, when you look at the cost of a license and the included cloud, web, & mobile inclusions it is still a very affordable offering. You can do a lot, and the value you should add to a project makes the license cost trivial.
There is no real competitor to the stack though - which I feel they need urgently to force both them, and the competitor, to pay more attention to their user base and efficiency.
When Esri staff say you need a decent PC to run Pro (not getting into data processing, just give a good UI experience) , I read it as recommending a PC that uses more power than should be necessary to complete a simple task. At the same time I see Esri personalities presenting at environmental events about how we can better map impact/change/benefit/resources/whatever using Esri products.......
Support the Idea to offer a Pro Low Power Mode.
<End Friday rant />
RandyMcGregor_BMcD
This resonated. Two things to add:
The batch functionality is extremely disappointing. You can only pick one component to 'batch.' In ArcMap, you could batch the entire process.
Highlighting columns is important to me, and not being able to right click and highlight a column has been another enormous disappointment. Going into the 'fields' pane to do this simple task is cumbersome.
Some of the more extreme lagging appears to be architecture-related, though.
Thanks for your input.
AlfredBaldenweck
See this Idea for batch processing, if you haven't voted on it already: ArcGIS Pro: Add Multi - field Batch Geoprocessing ... - Esri Community
For the highlighting, I see you've already upvoted this one, but it might be helpful for other people in this thread to see as well: Field Highlight using basic colors - Esri Community This one may also be interesting to you Add Highlight option to "Alter Field (Data Managem... - Esri Community
RandyKreuziger1
Also, canceling  esri geoprocessing tasks rarely ever works.  Mostly the task just sits there never finishes so the user has to kill Pro from task manager or Pro crashes.
WDFWAdministrator
For those going to the UC, stop by the Pro island and let your voices be heard.  Rather than adding new functionality ESRI should look into these performance issues.  Also, UC attendees will be given a pre-conference survey to fill out.  One year I received a call from our ESRI account manage to ask me about comments I made about metadata issues.  I was pleasantly surprised to hear from them and a follow up after the UC.
