how to speed up bulk route analysis?
669
02-27-2024 12:20 AM
Labels (2)
RavenSchmidt
Hi folks!
I am currently doing a analysis of about 88.000 Route using arcpy. No suprise this is taking it's time.
I have already switched from arcpy.na to nax, use parallel processing, spatial indexes and disabled log metadata and log history for the process. Also I am doing most of the work in memory.
Might there be additional tricks I could use. I read somewhere that batch solving of routes might be a thing, however this seemingly only applies to the apache arrow format...
Thank you
DanPatterson
the last I saw about large network analysis was this
Esri/large-network-analysis-tools: Tools and code samples for solving large network analysis problem...
... sort of retired...
RavenSchmidt
Hi Dan,
thank you for your response. These scripts do not solve my problem since I am doing another type of analysis, but maybe I can pull a few tricks out of them.
Har det bra!
