How to put a border on a layout (not just the map frame border)
27151
10
03-03-2021 07:14 PM
by Anonymous User
Not applicable
In Pro how would I get a layout to have a border? Not just the map frame but the whole layout (I want to be able to only insert the map frame in part of the layout).
Thanks!
LindsayRaabe_FPCWA
MVP Regular Contributor
If you want the border to match your map frame, then best to use the map frame border symbology to get what you want (you can offset lines like in my below demo).
If you want it separate to your map frame, then a rectangle graphic is the simplest I can imagine.
Lindsay Raabe
GIS Officer
Forest Products Commission WA
