I work with the map of the UK divided into about 5,000 polygons. I'd like to measure the ruggedness of terrain by a polygon with TRI or any other index but can't find the right tool for this task. Could you recommend a solution?
I was glad to see your question as I did not know of TRI and I have a use for it. A little googling found this: https://community.esri.com/t5/water-resources-blog/terrain-ruggedness-index-tri-and-vector-ruggedness/ba-p/884340
Thank you, I saw this post too. The trouble is I can't find anything like Arc Hydro functions in my system. Can you see them in yours?
Hi Mikhail,
To calculate the TRI in ArcGIS, try this workflow:
Other software packages that calculate the TRI include QGIS, GRASS GIS, and SAGA GIS. The specific steps for calculating the TRI may differ slightly between these software packages, but the general workflow should be similar.
Hi Omar,
Thank you very much for your advice. Could I use this map as a DEM https://environment.data.gov.uk/image/rest/services/SURVEY/LIDAR_Composite_1m_DSM_2020_Elevation/ImageServer ?
Kind regards,
Mikhail
Hi Mihhail,
In terms of using a DSM instead of a DEM, it depends on your specific analysis and the data you have available. For example, DSMs include the height of all features on the ground surface, such as buildings and trees, while DEMs represent the bare earth surface. If you are interested in measuring the ruggedness of the bare earth surface, then you should use a DEM. However, a DSM may be more appropriate if you want to include all features on the ground surface in your analysis. Remember that DSMs may produce values higher than DEMs since they include the height of objects on the ground.
In any case, it is essential to understand the data's characteristics and limitations, such as its spatial resolution, accuracy, and vertical datum, before using it for any analysis or modelling.
Omar
Thank you for your explanation. I found a DEM and followed the workflow you suggested. It all works, except for the last bit: I cannot find a Ruggedness Index tool. I have a Spatial Analyst license, but this tool is nowhere to be seen! Could you advise how you access it?
I apologize for the inconvenience. Please note that the Topographic Ruggedness Index (TRI) tool is a custom tool exclusively available for our Enterprise users.
However, I have investigated its structure and found that you can calculate TRI using a simple formula in Raster Calculator. I have provided a short video on creating TRI from DEM in ArcMap, which you can access through this link: (194) Topographic Roughness Index (TRI) from DEM / ArcGIS - YouTube
I hope this information is helpful.
Best regards,Omar
I am still struggling with this error. I went to Environment and changed the location of Scratch Workspace (see attached) but this did not help. What else could I try? It is so frustrating to stop just one step before solving a problem!
Sorry to have abandoned you, but I have not actually installed the ArcHydro tools myself. I found the resource and then my time went away. I will get back to it, but don't know when.
Hi Frank,
No problem, you have already helped me a lot! I am sure I will find a way to solve this issue.
