How to do Point clustering like in attached image?
1076
02-01-2021 12:41 AM
AnsarTass
I want to generate a point clustering like in Javascript Api specified below using Arcgis pro 2.7.0
https://developers.arcgis.com/javascript/latest/sample-code/featurereduction-cluster/
Robert_LeClair
Esri Esteemed Contributor
Related somewhat but if you share as a hosted feature layer to ArcGIS Online and/or ArcGIS Enterprise Portal you can configure clustering within a web map and then bring that web map into ArcGIS Pro via the Catalog Pane.  I "think" there's an enhancement request for a future release of ArcGIS Pro to do this workflow.
In addition, there is a workflow for Feature Binning via an Enterprise Geodatabase feature class if your data is stored in that format.
