How to calculate position in a clockwise manner?
1311
12-01-2023 08:31 AM
Davec43
I have data with X/Y data that plots and I'm trying to get it to look like so:
I've tried near analysis, and it gets me close but doesn't label them in a clockwise manner. Is there any geoprocessing tool or arcpy process that I'm overlooking that will accomplish this?
DanPatterson
MVP Esteemed Contributor
slow week
aoi  # a square
array([[  0.00,   5.00],
       [  5.00,  10.00],
       [ 10.00,   5.00],
       [  5.00,   0.00],
       [  0.00,   5.00]])
def geom_angles(a, fromNorth=False):
    """Polyline/segment angles.
    Parameters
    a : array-like
        A Geo array or a list of arrays representing the polyline shapes.
    out = []
    dxy = a[1:] - a[:-1]
    ang = np.degrees(np.arctan2(dxy[:, 1], dxy[:, 0]))
    if fromNorth:
        ang = np.mod((450.0 - ang), 360.)
    return ang
geom_angles(aoi, fromNorth=False)  # -- option 1
array([ 45.00, -45.00, -135.00,  135.00])
geom_angles(aoi, fromNorth=True)  # -- option 2
array([ 45.00,  135.00,  225.00,  315.00])
cent = np.mean(aoi[:-1])  # -- now from the center of the points
vals = aoi - cent  # -- angles from the center
vals
array([[ -5.00,   0.00],
       [  0.00,   5.00],
       [  5.00,   0.00],
       [  0.00,  -5.00],
       [ -5.00,   0.00]])
geom_angles(vals, fromNorth=False)
geom_angles(vals, fromNorth=True)
... sort of retired...
VinceAngelo
Esri Esteemed Contributor
You can write your own, but I doubt there's any general purpose tool for this.
The atan2 function takes dy & dx parameters, but that's counter-clockwise from 3-o'clock,
so you'd need to reverse the sign and rotate.
- V
DanPatterson
slow week
aoi  # a square
       [  5.00,  10.00],
       [ 10.00,   5.00],
       [  5.00,   0.00],
       [  0.00,   5.00]])
    Parameters
    a : array-like
    out = []
    if fromNorth:
    return ang
vals
       [  0.00,   5.00],
       [  5.00,   0.00],
       [  0.00,  -5.00],
       [ -5.00,   0.00]])
Davec43
Thanks Dan!
