How to add in a set date to attribute table
3005
6
10-14-2021 04:26 AM
Labels (2)
AndrewEastop
Is there a way I can change the date in the DateCaptur field of my attribute table to say 06/07/2020 ? I had tried to do this as a calculate field expression but somehow came out with a date fro 1970!
Any help would be very much appreciated
2 Solutions
JayantaPoddar
MVP Alum
What about the following expression in Arcade? Put the date in double quotes.
"2020-07-06"
or
"06/07/2020"
Think Location
Robert_LeClair
Esri Esteemed Contributor
So I used Arcade for the Date calculation using Date(2020,5,7,0) on a Date/Time field and as seen in the attached file it calculated the field to be 6/7/2020 at 6 AM in this case.  The key is that the month field starts January as a zero and counts to 11 for December.
JayantaPoddar
MVP Alum
Where is the data stored? (Shapefile, File GDB, Enterprise GDB, etc.)
What expression did you use?
Have you tried (Arcade expression)
Date(2020,07,06)
Think Location
AndrewEastop
The data is sorted in a filegdb.
Have tried to do the same expression you have said here and that is what gives me the random date. Got 09/02/1912 this time lol
JayantaPoddar
MVP Alum
"2020-07-06"
or
"06/07/2020"
Think Location
AndrewEastop
The double quotation did the trick... i hate code!
thanks very much
Robert_LeClair
AndrewEastop
thank you for the reply Robert
