Table frames allow you to dynamically update them within a map series by using a page query, which is very cool. However, where a single map (within a series) has no records at all matching the page query you get an empty table and the field titles are still displayed on the layout map face when you export the map.
Is there a way to make ArcGISPro remove the table altogether and not display that if there is no data in the table? Because a table with no data implies to the end user that something is missing!
I figure this could be an oversight by ESRI, as when this happens with a legend item, although it shows you the legend placeholder in Pro, the export is blank as per this question , but that doesn't seem to be the case with table frames.
