Help with large file xy to line conversion
623
02-09-2023 03:24 AM
kwalampur
I am plotting a bathymetric survey which has an insanely large amount of coordinate points. I can plot it in arc pro however when I try to convert the points to a line using the xy to line tool it gets stuck on "pending".
DanPatterson
MVP Esteemed Contributor
it is locally stored data?
Have you tried a subset?
are you doing a geodesic or planar line type?
are you changing the coordinate system in the process?
Do you have lots of ram? or does "pending" mean that there is lots of disk writing of intermediate data
... sort of retired...
