geoprocessing tool, I get the error "Tool is not licensed"
1462
05-20-2018 05:56 PM
FrankFrench
I'm using the 21 day free trial, and following the Get Started With ARCGIS pro doing the "Venice Acqua Alta" project.  When trying to use the "Raster Calculator" geoprocessing tool, I get the error "Tool is not licensed".  This problem was mentioned by an other user, but the answer stated that using the 21 day free trial, that that feature should be licensed, which is what I am using.  So how can I fix it to complete the lesson?
TimOrmsby
Frank, an ArcGIS Trial includes a couple of advanced Pro licenses (which your screenshot shows that you have) and extension licenses. The Spatial Analyst extension you need should be available; it just apparently hasn't been assigned to your account. If you're the admin of the trial ArcGIS Online organization, you can assign the license to yourself. If someone else is the admin, you'll have to ask them to do it. This help topic explains how to assign the license: Assign Named User licenses in ArcGIS Online.
DanPatterson_Retired
do you have the link to save some time?
FrankFrench
You mean link to the post I was referencing?
https://community.esri.com/thread/210263-arcgis-pro-geoprocessing-tool-not-licensed
Or, here's a link to the tutorial I was following, which at the beginning uninstructed me to get the 21 day free trial.
https:/https://learn.arcgis.com/en/projects/get-started-with-arcgis-pro/lessons/analyze-acqua-alta-c...
And in fact, Here is a screen shot of the error.
error
And a shot of my license page info.
license
Hope some of this helps.
Thanks a lot.
AdrianWelsh
MVP Honored Contributor
Frank,
Is there a way that you can activate the license by clicking on the Project tab, then Licensing?
TimOrmsby
