GeoDatabase Connection Properties Fails
11362
31
02-06-2018 12:31 PM
rbae
Using ArcGIS Pro 2.1.1 with Oracle 12.1.0.2, I get the following error when I try to look at the GeoDatabase Connection Properties:
The connection works fine and I can do just about anything else with the GDB.  The TNS as not an issue so it appears that it is an invalid error message...
George_Thompson
Esri Notable Contributor
@VanessaSimps can you post an error message?
You may want to create a new thread for this.
--- George T.
VanessaSimps
I think I figured it out this time, data was registered as versioned. Once I removed versioning I was able to do what I needed. Thought, I can see instances where I wouldn't want to un-version things.. If it happens again, I will create a new thread.
thanks for replying
