GeoDatabase Connection Properties Fails
11517
31
02-06-2018 12:31 PM
rbae
Using ArcGIS Pro 2.1.1 with Oracle 12.1.0.2, I get the following error when I try to look at the GeoDatabase Connection Properties:
The connection works fine and I can do just about anything else with the GDB.  The TNS as not an issue so it appears that it is an invalid error message...
rbae
Kory,
Thank you for your help - the Oracle Easy Connect string did work for me.  Since there is a bug logged for the TNSNames issue, I will mark this as resolved.
-Ryan
MichaelVolz
Esteemed Contributor
So I did some testing where I created a database connection but did not save the credentials (I unchecked Save user name and password) and I then clicked on Geodatabase Connection Properties. When I did this I saw the Connection Properties dialog box appear where it has truncated the first 2 letters of the instance which would cause initial ORA-12154 error as it cannot resolve the database instance because ArcPro changed the name by truncating the first 2 letters.
rbae
Michael,
I think you nailed it.  I was able to reproduce this as well.  I then added a TNS entry that duplicated the original, minus the first two characters of the TNS Name, and it worked.
MichaelVolz
This thread is answered if your org allows the use of Oracle Easy Connect which my org does not for both security and maintenance reasons during enterprise upgrades.  Hopefully, the diagnosis I have provided will help ESRI to fix the root cause of this issue for newer versions of Pro.
KoryKramer
Esri Community Moderator
Thanks for the comments here rbae‌ and mvolz47‌  I just wanted to pass along that the truncation behavior noted here has been included in the notes of the defect that the development team is assessing.
MichaelVolz
Thanks for passing that info along to development Kory.
KoryKramer
You're welcome!
MichaelVolz
Kory:
Would you be able to share the bug # that you say was logged for the tnsnames issue?
KoryKramer
This is the bug I was referring to that is open and under investigation:
[BUG-000096686: Unable to access 'Geodatabase Connection Properties' when connection is created using the Transparent Network Substrate (TNS) name for an Oracle geodatabase.]
MichaelVolz
Kory:
I created a tech support case and this is the bug that the analyst associated my case with.  My question on this bug is that it's status is New but it was created almost 2 years ago (5/23/2016), which does not seem new at all.  As such when does a Bug move out of New status (e.g. time period)?
