Field width resets after I calculate a field
2130
05-21-2021 09:21 AM
Labels (2)
RobertHursey
After Pro upgrading from 2.5.1 to 2.8, when I select records and calculate fields, the field widith reset to the default width.  This never happened before the update.  Is the a reason/solution for this issue?  I have removed the layer and re-added, restarted the map, restarted the machine, tried different projects, and finally made a new project in 2.8. The problem persists regardless of what I do.  I calculate fields all day long and I need to be able to adjust them to read all text.
DanPatterson
Contact Tech Support and file an issue.  It has been reported here recently (can't find it now).
Things get addressed when cases are filed.
... sort of retired...
DanPatterson
RobertHursey
I don't appear to be set up to contact customer support.  This is my line of contact.
DanPatterson
hmmmm  Try "requesting" permission through your My Esri link.  Your contact person will get a request to grant you permissions.  If you know them... fire off a request directly.
@KoryKramer an FYI.  If you could check internal links to see if this has a case #
There are older related links which are "implemented"
For example
BUG-000106836: The width of a column is adjusted to the default siz.. (esri.com)
KoryKramer
Esri Esteemed Contributor
Thanks for tagging me, Dan.  We're looking into this and will follow up on this thread.
