custom symbols in ArcGIS Pro
26006
11
10-04-2015 08:07 AM
GideonSinger1
Hello, I am having trouble finding a way to add custom made symbols (probably a .png file) to a point feature class in ArcGIS Pro. Any advice?
XanderBakker
Esri Esteemed Contributor
Activate the symbology of your point layer:
Choose:
  • Properties
  • Change from "Symbol" to "Layers"
  • Change "Shape marker" to "Picture marker"
  • In Appearance insert picture from "File"
HectorBorro1
Are there any specs on the .PNG file to consider? I'm importing the symbol but appears pixelated and looks too ugly on the map...
by Anonymous User
Not applicable
Hi Xander Bakker
I have done as directed above using a PNG file, but there is a quality loss - the symbol is blurry.
Should any specs be specified for the symbol?
XanderBakker
I could do some testing (trail and error) to see if there is a "best" size to be used, but I think it is better to tag Kory Kramer‌ who might be able to provide us some recommendations.
KoryKramer
How have you set the Quality?  Is it Draft as the default or have you adjusted that?
Marker symbol layers—ArcGIS Pro | ArcGIS Desktop
MargotDehem
Hello @KoryKramer
I have some trouble finding info about this quality choice ? Can you specify some info about when it's best to chose draft, text, or picture ?
Thank you,
Margot
KoryKramer
Sorry, I don't have any information beyond what is in the documentation.
Lake_Worth_BeachAdmin
Any solution regarding the loss of quality (pixelated) of .png images?
TimothyPoe
Was that on the maps or the Wordpress pages linking to the maps?
Best,
Tim
