I'm looking for the Crime-Analysis Add-in but Esri is no longer offering it for 2.6. I'm not ready to upgrade from 2.6.3 to 2.7 because I like to wait until the new version is vetted more or until 2.7.1. It is really disappointing that versions prior to 2.7 are no longer available. Fortunately, I have some flexibility on the version of software I use, but there may be organizations that cannot upgrade for some time. Esri, please don't deprecate Add-ins like this so fast for previous Pro versions. Is there a technical reason or a management decision? Please make the previous version available. Thanks.
Solved! Go to Solution.
To Dan's point, starting at ArcGIS Pro 2.6, the Crime Analyst Add-In functionality is part of the "core" ArcGIS Pro application. The toolbox information is here and if you go to the Project-Options->Application->Crime Analyst, check the box to "Show Crime Analyst tab"
these?
These in Pro 2.7 by default
@Robert_LeClair Hi There. i feel like i'm missing something; i can see the tools in my toolbox on 2.6 but i don't see Crime Analysis listed in the File > Options > Solution .. i tried installing the 2.7 add-in on 2.6 and it does appear to install, but also gives a warning that it can't install, but still there isn't a Crime Analysis line item available in the File > options. I feel like there is something very obvious i'm not doing. any ideas?
Hi - I'm running ArcGIS Pro 2.7.3. When I go to Options->Application->Crime Analysis, I can click the box for "Show Crime Analysis tab" - see graphic below. When I return to the project, I have a Crime Analysis tab and two toolboxes Crime Analysis and Safety Tools and Crime Analysis tools - see graphic below. If you still don't see any Crime Analysis information, I recommend you rename the ESRI folder in your C:\Users\<user_profile>\AppData\Local C:\Users\<user_profile>\AppData\Roaming to ESRI_OLD. Try again. If this doesn't work, then I recommend running an Repair operation on your ArcGIS Pro installation. Good luck!AGP_CrimeAnalysis.JPG
Thank you very much for that important information. I'm sorry it seems so obvious now. I'm still confused why the Crime Analysis solution is available at Crime Analysis | ArcGIS Solutions. Does it provide other functionality.
You're welcome Brian - glad it worked out. With regard to the Solutions Gallery, the link you provided mentions the product is no longer available to download and redirects to a new Solutions page. I don't believe it provides additional functionality over the AGP functionality and appears to be a way to deploy it to one's organization - but could be wrong.
There is a download here for 2.7 http://appsforms.esri.com/products/download/index.cfm?fuseaction=download.main&downloadid=2174 which you get to from here
