creating tile cache using pro based cached service
1891
07-15-2024 09:20 AM
Labels (3)
BanchanaPandey
We have been converting ArcMap based tile cache service to a pro based service. For the creation of tiles, we use arcpy.server.ManageMapServerCacheTiles geoprocessing tool.  We have noticed that the process takes almost double the time in arcgis pro based service versus the same thing in arcmap based service. There are no changes, same scale, same area of interest, same enterprise geodatabase data source and the time we run the job is also the same.
The 10.8.1 environment that is used for cache generation based of arcmap published service  is a site of 6 machines with 4 cores cpu each, versus the 10.9.1 environment which is being tested for pro based service is also a site of 6 machines with 8 cores cpu each. The memory on the 10.9.1 is higher than the 10.8.1 as well, but still the tile generation is taking way longer. We also ruled out any issue with our script, by running the tile generation directly in ArcGIS Pro, and are seeing the same results.
Is this normal for tile generation through arcgis pro to be slower than running the same tool in arcmap?
Any ideas?
David_Brooks
MVP Regular Contributor
@BanchanaPandey that's a really good question. I also do our caching in pro with 10.9.1 on our image server and have found it to be a lot slower than previous. However, I've found caching locally through Pro to be fast. Our image server only has 6 vCPUs whereas our VDI machines running pro have 8, but the speed is way faster than just 33% more (based on the increased core value).
We also have a staging system that we've upgraded to 11.3. If I have time, I'll run a test to see which caches faster.
Have you set your number of cores to -1 in the cache process?
David
..Maps with no limits..
BanchanaPandey
Hi @David_Brooks
No we have not set the instances to -1. For caching, we have set minimum number of instances to 1 and for max instance, we are using the old formula n+1 where n is the number of cores on each machine. So 9 instances on each machine, and because its a site configuration of 6 machines, so that makes it 54 instances in total. We are not using shared instance yet and still use dedicated instance, to compare same kind of settings between the 10.8.1 and 10.9.1.
We are creating tile cache of vector data, not imagery. Yes, please share what your results are for 11.3 environment.
Banchana
BanchanaPandey
@David_Brooks  did you get a chance to test yet? we moved our shared cache location from a shared network drive to locally on the server machine and the time significantly  improved.
We are seeing another issue now. We are on 10.9.1 and have a script to create the manage map server cache tile using a python script. After we run the job, we get this error below:
MAPSERVERERROR 001470: Failed to retrieve the job status from server. The Job is running on the server, please use the above URL to check the job status.
Failed to execute (ManageMapServerCacheTiles).
The job does finish on the server, but the script fails on the server.py during the call to convertArcObjectToPythonObject method. I am using the "WAIT" parameter in the call for wait_for_job_completion, but still errors out and the error it returns does not have the job url either that it  mentions
Any idea or similar situation if anyone has encountered this, please share.
