Conversion between Python and Arcade
2903
6
12-12-2023 02:51 AM
HusamJubeh
I can write an expression in Python to get new data in a specific order through the expression ( !BQCODE![3:5] ) but I do not know how to write that expression in the Arcade language.
Is there anyone who can help?
Gratefully
Tags (1)
MicZatorsky_AEC
In the Calculate Field tool, the Arcade expression
Mid($feature.BQCODE, 3, 2)
is the equivalent of the Python expression
!BQCODE![3:5]
 Python uses a start index and an end index.  Arcade uses the start index and the number of characters.
DanPatterson
MVP Esteemed Contributor
Function Reference | ArcGIS Arcade | ArcGIS Developers
may be of use.. perhaps the Text portion
... sort of retired...
HusamJubeh
Thank you
But I want to get to the expression quickly. I searched for it but did not find it.
Can you write the expression here??
Gratefully
JoshuaBixby
It helps to provide information about data types and an example or two.
HusamJubeh
correct
but I cannot reach the correct expression in Arcade, but in Python I know it
can you help me ؟
Gratefully
MicZatorsky_AEC
!BQCODE![3:5]
HusamJubeh
Thank you 😍
