Combine lines like merge them as well as summing thier field value.
324
03-20-2025 03:18 PM
dhruvparmarca
I am trying to combine value of field of overlapping lines in a feature class.
I have several lines, some are overlapping each has flow rate of different values. I want to combine those lines.
For example,
----------------------------------       (Value 3)
-----------                                    (Value 4)
_______..............................
(3+4)               4
DavidPike
MVP Notable Contributor
make sure you make a copy of your data first, as this will edit the existing dataset.
Planarize lines should be run to split the segments at overlaps Planarize polyline features—ArcGIS Pro | Documentation
Then use a spatial join to get all overlapping attributes (target = planarized copy, join features = original data, Match option = 'Within' (I think, or contains, I get confused - see what happens!)) - Spatial Join’s hidden trick on how to transfer att... - Esri Community
