Cannot see my file
725
06-26-2022 10:26 AM
JuhiKamra
Hi, I have been working on these files. I cannot see any of the data I put in this. Please help me regarding this
DanPatterson
MVP Esteemed Contributor
Check you map's table of contents... if they aren't there, add them (drag from catalog).
If they are in the table of contents, right-click on a layer and select zoom to layer"
... sort of retired...
JayantaPoddar
It seems your map frame is closed. Please insert a new map frame first.
In the Map frame, you could add the desired data from Catalog pane or Add Data option.
Think Location
