Can't get right temperature range after calculating land surface temperature
4187
08-20-2023 11:12 AM
sturaro
Howdy! I've been trying to calculate the land surface temperature of Ghana by following exactly this post: https://www.gislounge.com/how-to-use-arcgis-pro-to-map-urban-heat-islands. I have used Band 4, Band 5 and Band 10 I downloaded from USGS. However, after using the following formulas and creating my LST outcome layer, I get weird extreme temperatures (61 to 91 degrees) and I don't understand why:
My formulas and values are:
1) Top of Atmosphere (TOA) = 0.00038*”B10.TIF”+0.1
Radiance Multiplier = RADIANCE_MULT_BAND_10 = 3.8000E-04 (so 0.00038)
Radiance Add = and RADIANCE_ADD_BAND_10 = 0.10000, both from the metadata
2) Brightness Temperature (BT) = (1329.2405/Ln((799.0284/"TOA")+1))-273.15
K1_CONSTANT_BAND_10 = 799.0284
K2_CONSTANT_BAND_10 = 1329.2405, both from the metadata
3. NDVI = Float (band5-band4) / (band 5+band 4)
4. Proportional Vegetation (PV) = Square((“NDVI”+0.121068)/(0.459455+0.121068))
NDVI min is -0.121068
NDVI max is 0.459455, both from NDVI outcome layer
5. Error Correction / Emissivity (E) = 0.004* ”PV”+0.986
6. Land Surface Temperature (LST): (“BT”/(1+(0.00115*”BT”/1.4388)*Ln(“E”)))
By looking at the formulas above, could someone help poor me identify any issues? 🙁
I didn`t get any operation errors while running the different steps/formulas in the raster calculator, and have tried different things to correct that, including extract by mask tool as in this video where the guy got the same error: https://www.youtube.com/watch?v=EzavTBq-1wM&ab_channel=VikasGhadamode, but it didn't work for me.
Considerations: In the LST formula, I`m not sure if using 0.00115 is right, since I`m using Band 10. But I also tried to use 0.00106 as per below, but it wouldn't work either. Maybe there is a value wrong somewhere and I can't see it...
Band 10 TIRS 1 ---- 10.6 – 11.19
Band 11 TIRS 2 ---- 11.5 – 12.51
In case anyone is feeling super nice and wanna help me solve this mystery 😅, here's the link to download the files I'm using: https://we.tl/t-Pum2lyBqWU
Thank you so much - forever greatful 😎
Roger
Reference paper: Estimating Land Surface Temperature Using ArcGIS Any Help Contact Mr.Vikas Ghadamode--Vikasghadamode7@gmail.com WhatsApp Number= +918421031398 Special Thanks for What I am Using Software: https://amzn.to/3BO5IMF GIS BOOKS: https://amzn.to/3xmM333 Mic: https://amzn.to/3iYN77P HP ...
FarzadHashemi
Hi Sturaro! Have you solved the issue? I am having the same problem with another city and the LST range seems very high.
SelvarajDharshani
Hi Sturaro and FarzadHashemi
Have You guys solved your problems? I also faced the same issue but now I got the correct output.
To get around that problem, I downloaded the Landsat 8 data (collection 2 Level 2) file. If the other methods yield the correct results, we can use that data to obtain the correct output.
darkmagcin
helo my friend i have the same problem as you,please help me
LydiaWong
Hi! I know this is an old post, but in case it's still useful and in case others run into the same thing... I had the same problem (got really high unrealistic values after watching the same video as sturaro). I eventually figured out that it had to do with me using Level 2 data instead of Level 1 data. The steps outlined in the video are if you are using Level 1 data. The newer Landsat data (Level 2) have more processing and my understanding is that all you need to do is apply the scaling factor and additive offset to Band10: How do I use a scale factor with Landsat Level-2 science products? | U.S. Geological Survey
e.g. Band10*0.00341802 + 149
This will produce a value in Kelvins, so I think we'll have to subtract 273.15 to get ST in celsius.
This seemed to work for me!
@sturaro  I think your file is indeed a Level 2 file because the "L2" after "LC09" in the file name usually denotes the level 🙂
@FarzadHashemi  @darkmagcin @SelvarajDharshani -
