Can’t calculate field to <NULL> using None
284
6
07-25-2024 11:27 AM
Jim_Riedmann
I’m using ArcGIS Pro 3.3.1.  I have an attribute table with a date field.  I want to replace some of the values in the field with <NULL>.  Using the field calculator, with the Expression Type set to Python, I type None in the space for the new field value.  I get Warning 003571 and the value in the table stays the same.  I can’t find any way to get <NULL> into the date field.   I looked at the Fields view and NULL is allowed for that field.
Eugene_Adkins
Using Field Calculator/Arcade, type "return null" and if the fields are nullable this should work.
Eugene_Adkins
Jim_Riedmann
That method works, thanks very much.
KenBuja
Even though you do get that warning, the date values are calculated to null.
Jim_Riedmann
No, they are not calculated to NULL.  They remain unchanged.
KenBuja
That's curious, since it worked in my testing. I created a new date field, copied an existing field's dates into the records, then set them to null again. The screen image was the last step in my process.
