Can I populate a map with a two digit FIPS county code?
3504
02-07-2022 12:50 AM
Labels (3)
chagithebear
Hi all! I have a CSV file with state-county (California) FIPS codes (two digits). Can ArcGIS Pro populate or recognize state codes? If yes can someone walk me through how to populate data with my specifications? Thank you all so much.
RobBurke
If I open your table in a map in ArcGIS Pro, and then right click the table and click Geocode.  The only Locator I can select is the ArcGIS World Geocoding Service.  Which doesn't have an option for FIPS codes.  Do you have any other locators to choose from?  If not you would then have to create your own locator, which isn't all that difficult. Plus if you are using your own locator there are no credit costs involved. (Just noticing that your FIPS above for Alpine county should be 03 - FIPS are odd numbers for counties).
Here is a posting to help create your own locator. https://pro.arcgis.com/en/pro-app/latest/help/data/geocoding/fundamentals-of-creating-a-locator.htm
Robert Burke
chagithebear
countyagecatrateer1719pop1719county code
Alameda1-2 years277.1343123793.901
Alameda10-13 years138.7323232862.801
Alameda14-17 years183.5423230547.501
Alameda18-34 years559.56149109910101
Alameda3-5 years293.9541184077.801
Alameda35-64 years366.67172195626301
Alameda6-9 years268.9620230542.201
Alameda65-100 years211.71442681063.401
Alameda<1 year183.411462147.601
AlamedaAll ages356.817127480040001
Alpine1-2 years0051.502
Alpine10-13 years00243.602
Alpine14-17 years00221.102
Alpine18-34 years8374477.902
Alpine3-5 years0079.702
Alpine35-64 years136.321467.402
Alpine6-9 years0011402
Alpine65-100 years00814.302
RobBurke
Are you asking about adding a new field, like stateAndCounty Fips?  If you did that you could calculate the values in the new field by taking California's FIPS 060 and concatenating the county fips.  So above you would end up with values like 06001 and 06002.
Robert Burke
chagithebear
Hey Rob, just to be clear. ArcGIS can only recognize a 5 digit zip code. What I am asking is if I provide the software with only 2-digit county FIPS, would ArcGIS be able to populate the data?
RobBurke
Robert Burke
