Can I import csv file of line data?
3588
01-04-2023 06:05 PM
asdfjljwg
Hello, I have a csv-structured dataset as follows :
IDx1y1x2y2
1141848784442592141848864442595
2141845044443068141845114443076
This is a line dataset, whose x values are latitude and y values are longitude of two points of each line.
But I have no idea how to import this in line form, because the only way importing csv file into GIS I've known so far is just dropping it and clicking 'XY data display' menu. And if I do this, I can use coordinates of only one point. Thus, I can only import this csv file in only point form.
So is there any way that I can import this in line form?
AhmedFathy74
You can easily use xy to line geoprocessing tool and you will be able to add this CSV file in line form
Ahmed fathy
JohannesBierer
I think you will need python to do this - someone posted a solution here:
https://gis.stackexchange.com/questions/34647/creating-lines-from-points-pair-coordinates-with-arcpy
I tried the code of Chad Cooper there with four points with the old cursors ... it seems to work.
Here is the code I used:
import arcpy
fieldnames = ['X1', 'Y1', 'X2', 'Y2']
# Needed input/ output files
inExcel = r"YOURPATH\Points.xlsx"
FGDB = r"YOURPATH\Points2Lines.gdb"
outTable = "Coords"
outLines = "Lines"
arcpy.env.workspace = FGDB
arcpy.env.overwriteOutput = True
# Change to your Sheet name!
arcpy.conversion.ExcelToTable(inExcel, outTable, "Test")
in_rows = arcpy.SearchCursor(outTable)
point = arcpy.Point()
array = arcpy.Array()
# Without Spatial Reference, please change!
arcpy.CreateFeatureclass_management(FGDB, outLines, "POLYLINE")
featureList = []
cursor = arcpy.InsertCursor(outLines)
feat = cursor.newRow()
for in_row in in_rows:
    # Set X and Y for start and end points
    # Change here to your field names
    point.X = in_row.X1
    point.Y = in_row.Y1
    array.add(point)
    point.X = in_row.X2
    point.Y = in_row.Y2
    array.add(point)
    # Create a Polyline object based on the array of points
    polyline = arcpy.Polyline(array)
    # Clear the array for future use
    array.removeAll()
    # Append to the list of Polyline objects
    featureList.append(polyline)
    # Insert the feature
    feat.shape = polyline
    cursor.insertRow(feat)
del feat
del cursor
asdfjljwg
Thank you! I didn't tried this yet, but this seems very fit for my purpose.
AhmedFathy74
Ahmed fathy
