Can ArcGIS Pro Tasks capture an event, like a feature edit?
669
01-10-2020 01:53 PM
AZendel
If somebody splits a polygon, can you capture that event, such as "on feature change"? When a polygon split (or merge) is made, I'd like to update our field that stores the acreage for the split feature and those that it intersects.  In other words, use the calculate field tool to do AREA_ACRES = Shape.Area / 43560.
KoryKramer
Esri Community Moderator
SreenivasaRaoPigili
Hi A Zendel‌,
  I believe you can achieve this by using 'Calculate Field' options in the Actions --> When Exiting the Step., within the Task steps.
