Caculating Statistics On Already Mosaiced Raster
2115
01-05-2023 07:36 PM
Labels (3)
IanHuerta
Hello!
Just for a refresh, Is it ok to calculate statistics on a mosaic raster, or should I have calculated statistics on the separate rasters beforehand?
Thanks!
-Ian Huerta
Tags (3)
IanHuerta
Also, I know someone asked in 2011 on an old version, but if someone could tell me what to look for in case my statistics have already been calculated, thanks as well!
-Ian Huerta
JayantaPoddar
You can Calculate Statistics for a Mosaic Dataset as well. However, note "When using this tool to calculate statistics on a mosaic dataset, the statistics are calculated for the top-level mosaicked image, not for every raster contained in the mosaic dataset."
Think Location
IanHuerta
To calculate for each should I calculate them separately, then mosaic them?
Sorry if this feels like an obvious. 🙂
MaxPetri
Your mosaic dataset will have the option to "Calculate Statistics" see screenshot when right click in the Catalog, this will complete it for all records in your mosaic dataset.
MaxPetri
Can anyone explain what "top-level mosaicked image" explicitly means? Which rasters will be excluded from the stats?
