ArcGIS Pro: Label Settings Window Closes Before I'm Finished
8542
22
06-06-2019 02:26 PM
deleted-user-M1PJmvnAl3Pp
A coworker and I have experienced a possible bug regarding labeling settings in ArcGIS Pro. We are both on version 2.3.2 and run Windows 10 and 7 respectively.
It manifests itself as follows:
1. Right click on a layer in the Contents pane and click on Labeling Properties....
2. Go to the Position tab (note: there is no Apply button at the bottom of this window). Change any setting.
3. As soon as a single setting is changed, the change is applied, the Labeling Properties window closes, and is replaced with a window that says "Select a feature layer in the Contents pane".
This is really annoying because I cannot change multiple position settings at a time. I have to go to contents and get the Labeling Properties window open again, make a change, watch it close, and do it all over again to make a third change, and so on.
Is anybody else experiencing this?
Tags (3)
WendyHarrison
Hi Lenora - thanks for letting us know!
JosephChampagne
This is still happening six years later, very annoying UI behaviour.
DataOfficer
I'm also still seeing this in 3.3.0.
