I have been attempting to calculate Square yards in Arc Pro 2.7 and have run into a issue with the results. I am getting approximately half of the expected value. A one square yard area is coming up as .518. I tested the calculations on acres and square feet and they are all exporting incorrect values as well. I attempted to create new feature classes in several different spatial references to rule that out.
*Update: The Issue was resolved by having the same locale map frame and data spatial reference
We switched the map frame and the data to State Plane Michigan south and that seems to have done the trick. Thank you @jcarlson , @JoshuaBixby , and @DanPatterson for your time and assistance.
