Arc GIS Pro Layout Export with attached jpeg into .aix not working
1258
11-14-2024 01:58 PM
jkys11
Hello Arc GIS Pro community, I am making a series of maps for which I want to use google earth satellite image as base that I have downloaded as a .jpeg and exported as .tiff to insert into the GIS project. After inserting it and lining it up with the project base map I am unable to export my layouts with this inserted satellite image. I exported the layout into .aix file and when I open it in Illustrator the satellite image I have inserted is missing. I found a post from Esri that says to check the box 'Save Picture as Part of Document' however I am unable to find this box to check it. Desperately looking for a fix, any help is appreciated. Please see screenshots attached
jkys11
that is actually the built-in Arc GIS satellite base. there should be one more layer with the attached satellite image. I actually figured out where the issue was yesterday, just needed to save the georeferenced image as a layer and then it exports with it. Thank you though!
MelanieRiley_USFS
I noticed in 03.png your World Imagery layer is there but it is turned off. The little box to the left of the layer should have the eye symbol activated. Is it not appearing when you have it toggled to visible?
jkys11
