Animation of netCDF file using Make Multidimensional Raster Layer
3787
12-22-2021 06:24 AM
Labels (2)
JRobin
I am new to the use of netCDF (.nc) data. I am attempting to create an animation from a netCDF (.nc) file containing flood velocity data at a uniform time step. If I use the "Make NetCDF Raster Layer" I am able to create raster snapshots at each time increment which correctly show the velocity data at those increments, verifying that the netCDF file contains the necessary data. When I attempt to create an animation using the "Make Multidimensional Raster Layer" as an intermediate step, I am able to generate the multidimensional raster, but when attempting to visualize the data it is blank. I am attempting to visualize it through the animation bar that appears when the layer is selected.  I have not had any luck using the built in animation tools, either.
Are there resources available to help troubleshoot this issue? The file I am working with is included in this post.
JayantaPoddar
Once I execute Make Multidimensional Raster Layer (Multidimension)—ArcGIS Pro, I am able to animate the Multidimensional Raster Layer (Animation video attached). Tool parameters can be seen on the right.
ArcGIS Pro 2.9.0
Think Location
JayantaPoddar
ArcGIS Pro 2.9.0
Think Location
JRobin
Thank you @JayantaPoddar! I appear to have been making a simple mistake. It is working in 2.9.2.
