Analyze Polygon Width At A Certain Point
1493
06-23-2022 09:13 AM
MikeMadson
I am hoping to be able to analyze the width of a polygon at a certain point, such as a certain distance from a particular feature or from an edge of the polygon I am hoping to analyze. How can I do this with many polygons quickly and not have to do it manually, and be able to add the output as a new field in an attribute table? How do I do this? Does it involve scripts and/or models? I use ArcGIS Pro. I was using version 2.9.3, until updating to version 3.0.0 on Tuesday, June 28, 2022.
jcarlson
What kind of polygons are these? A notion of "width" might make sense with rectangular polygons, but I think you're going to run into some trouble reliably identifying the "axis" along which this width is measured, especially if the polygons have irregular shapes.
- Josh Carlson
Kendall County GIS
MikeMadson
The polygons are close to rectangles, but are irregular. Here is a picture of some of those polygons.
DanPatterson
try  Minimum Bounding Geometry (Data Management)—ArcGIS Pro | Documentation
using Rectangle by width.
... sort of retired...
DanPatterson
What are you trying to quantify specifically?
How does the start location enter into it?
How is distance important?
Are the polygonal features directionally aligned as a group?
Do you have an image of  some sample polygons that you are dealing with?
