Am I the only one with broken/mismatched Select and Explore tools
2506
02-07-2019 09:46 AM
CheyneHadley
Whenever I'm using either the Select or Explore tools to navigate and select feature, ArcGIS Pro 2.3 will switch and/or break the functionality.  This was rare in 2.2, but now it breaks within 5 minutes of opening the software--every time.
Specifically:
1. click Select tool
2. select a feature
3. click somewhere in any open attribute table.  The selected tool change to the Measure tool
4. click the map
5. now the select tool pans the map
The mouse cursor is still the Select tool, until I click on the map, where it will change to the closed hand cursor until I release the mouse button.  It only pans the map, as I still have to select Explore if I want to identify features.  Even though the Measure tool appears to be selected at this point, you cannot measure anything.
To Return to Normal:
0. the Clear button clears the selection, but does not fix the situation
1. click the Select tool again to select features or the Explore to identify features
To Measure features:
1. click either the Select or Explore tool to reset the bug
2. click the Measure tool
(view in My Videos)
Sometimes, when I'm using the Explore tool, it suddenly starts selecting features instead of panning the map.  This is less common, and I don't have a specific use case to recreate it, but it's still related and worth mentioning.
Kory Kramer
KoryKramer
Esri Esteemed Contributor
What antivirus software are you running?
CheyneHadley
ESET Endpoint Antivirus
Version 6.5.2107.1
KoryKramer
Sorry that you're running into this, Cheyne, and thank you for pointing it out.  We're able to reproduce the behavior so I've logged the following bug:
[BUG-000119926: When Measure tool is added to another ribbon through the Customize the Ribbon options , with Select tool active, clicking in an attribute table highlights Measure tool in ribbon, and switches Select tool to Explore tool functionality.]
If you would like to be attached to this bug for tracking purposes, please DM me or email [email protected] with your customer number.
Thank you.
CheyneHadley
Thank you for looking into this.
Matt-Goodman
I have noticed similar issues with ArcGIS Pro, in which the chosen tool seems to be different from the tool that the interface initializes.
